**Core Machine (Operating system/System info/Roon build number
Roon ROCK on Intel NUC i7 (1.7 - build 667)
Via Ethernet
Roon ROCK -> Roon Bridge to Minix Neo (1.7 - build 667)
-> Motu 8A audio interface (stereo - 3 way XO) to amps and speakers. Outputs are from 1-6 on the Motu.
Hi ,
I have created a 3 way XO and correction filter set using acourate. I have been trying to use the 3* stereo .WAV files in the convolver and am getting distortion and incorrect output. the 3* filters are placed into a zipped file with the .CFG file which lists the following ;
192000 2 6 0
0 0
0 0 0 0 0 0
Cor1S192.wav
0
0.0
0.0
Cor1S192.wav
1
1.0
1.0
Cor2S192.wav
0
0.0
2.0
Cor2S192.wav
1
1.0
3.0
Cor3S192.wav
0
0.0
4.0
Cor3S192.wav
1
1.0
5.0
I have set up-sampling to custom PCM , everything being resampled to 192K and have played around with the outputs to 5.1 .
Regards
Phil.
