I’m using the parametric equalizer for the first time. After choosing a filter type, I change the values of frequency, gain and slope. For example I choose for:
- filter type: peak/dip
- frequency: 100
- gain: 5
- slope: 2
When applying these values or tabbing out the fields, Roon changes randomly one of the three entry fields back to its initial value, e.g. gain is reset to 0. This behavior appears repeatably and seems like an error. Has anyone experienced this behavior before and how can this be solved?
thanks
Armin
