I had about three years old basic iPad as a Roon remote. My core is on 2018 i5 Mac Mini. I had constantly issues with Roon remote app crashing and needing to reload album art especially after resuming to app after listening. This was making finding music and songs to play less of an enjoyment. Mostly because of this I went and bought 2020 iPad Pro 12,9" because I thought that 6 gigs of ram would do the trick. Well it didn’t help. I have tried to increase and to decrease the memory for photos/artwork.
This is huge inconvenience (at least for me) and has lead me to use mostly Spotify. I am a lifetime subscriber for Roon, so this is not about cancelling my subscription
Is there anything that could be done about this issue?
Yes, you should contact support because I am using a second gen iPad Pro with 64GB of RAM to control my set-up without issue. Since that is virtually all I use it for there are only a handful of others aps loaded on the3 device.
I’ve shifted your post into Support because it sounds like something in your setup isn’t working properly. Can you provide full details of your system and network using this link as a guide.
Make sure to describe your network configuration/topology, including any networking hardware currently in use, so Support can have a clear understanding of how your devices are communicating.
Hello @optimaxi, my apologies for the delayed response here. I spoke to my team about what you’re experiencing and we would like to enable diagnostics for your iPad. Please reply to this thread with a timestamp (your local time) next time Roon crashes on the iPad and I’ll enable diagnostics for your account.
I also wanted to ask about any patterns you’ve noticed or a failure point when the app generally crashes as this will help my team isolate the cause of the issue.
Lastly, are you seeing this behavior on your iPhone?
I may have found a solution that helps. I cleared the image cache in my core and all my remotes. Then set the memory higher. So far it’s been way better. So I’ll see how it works and get back here, if the problem comes back.
