Windows 10 64 bit, i7-3770T CPU @ 2.5 ghz, 8 gb RAM, 1 tb hard drive, Roon Version 1.6 build 401
Qualcom Atheros AR946x, Wifi connection using comcast latest wifi router with fastest internet package over 150 mbs download speeds
Audio Devices (Specify connection type - USB/HDMI/ect.)
USB DAC on the home computer, I do have a PIA VPN however the ROON software seems to work fine on the core home computer. I have turned the VPN off on both core and ipad when trying to connect.
I have been using Roon on my home computer for a trial month. I stream Tidal and find the Roon software a big upgrade on the listening quality over Tidal and am considering buying a lifetime membership. I have three Bluesound Node 2’s in other areas of my home that I can control the output using Roon core on my home computer. I have downloaded the Roon software for my Ipad Pro 10.5 and for whatever reason it cannot connect to Roon. When I launch the app on my Ipad it finds my home computer as the core device and always says connection failed. Thus I haven’t been able to use my Ipad to control the music in other rooms.
I have Windows Defender as secondary and Iobit Malware Fighter 6.6 Pro as primary virus software.
