System info
Roon core is on:
Mac (Retina 5K, 27-inch, Late 2015)
Processor: 3,3 GHz Quad-Core Intel Core i5
Memory: 16 GB 1867 MHz DDR3
Roon build: 1.8 (build 783)
First had ORBI RBK 50 system, everything with ethernet cables (Audioquest)
Since last week new system Asus AX 6600 (Wifi 6) everything also wired. Tried this system because more people did have problems wit h ORBI router because of time-outs connection. But also with Asus the problem is still there.
Imac is wired with the router.
KEF LSX
Everything wired, master and slave speaker wired and ethernet also wired.
ROON settings:
No QMA support
Volume: on device
No volume maximum
max samplerate: - 96 kHz
Maximum bits per sample (PCM): 24
Activate MQA-core decoder: Yes
Multichannel Mixing: Downmix if necessary
Hello,
Since start with Roon i have often problems with playback music for a longer time. The music plays sometimes one hour, sometimes 20 minutes sometimes some minutes and then stops. When te music stops, the DSD/signalpath keeps saying that the processing speed is about 70-80 x.
I’ve tried everything; go on ethernet, go on wifi only, new ethernet cables, ethernet from KEF LSX to a switch, ethernet to my router, new router system etc. Nothing works!
Hope someone can help me…
