I am running version 1.4 (build 310) stable (64 bit) of Roon. I have Windows Professional 7 (64 bit). The computer is a Lenovo ThinkPad. It has an Intel Core i-5 - 4200M CPU @2.5 GHz w/ 8gb of RAM My music files are on a Western Digital 2 terabyte external hard drive. I am using Roon Remote on my IPad running iOS 11.3.1. I have about 50,000 tracks, the majority of which are from Tidal. The zone I am using to play through my stereo is through a Meridian MC200 (Sooloos). I am using the remote over my home WiFi network. The router provided by my ISP (Telus) is connected by ethernet cable to an Apple Extreme and it is plugged into an electrical outlet with a D-Link PowerLine AV cable. The other cable is plugged into the Lenovo.
I have several problems that have been occurring over the last month and a half:
Whenever the iPad goes to sleep (after 15 minutes or so), when I activate it, Roon loses the connection and the music stops. After the connection is restored the music will start again in most instances. This does not happen with my Sooloos app and it did not use to happen with Roon. I will sometimes use my iPad as a zone for listening with Bluetooth headphones and this problem does not happen with that zone. This problem happens with Tidal tracks as well as flac files from my computer.
Sometimes the music just stops on its own and I have to go to the IPad and push play again.
Sometimes the audio settings will change without warning so that I can only choose a zone that is either connected to the core or a zone that is networked. This happens with both the remote app on the IPad and with the desktop version as well. Sometimes, if I leave it for a few minutes, the other options will appear and sometimes I have to close and re-open the desktop version
On numerous occasions, once one of the other problems have manifested, I will push play, the sound indicator next to the song title is active, but there is no sound and the track timer does not move. It appears that the only way to rectify that problem is to close the desk top application and re-open it.
I tried deleting the app from my IPad and then re-downloading it, but that did not do anything. I did move my computer to another room and that coincided with the problem. However I moved it back 2 weeks later, but the problems have persisted.
Do you have any suggestions?
Bill Rowe
