Problems with Roon arc
I have problems with ROON arc after my internet provider changed the main internat station in the house. The error is this:
“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:504,“error”:“error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined”},
“external_ip”: {“actual_external_ip”:“77.aaa.bbb.ccc”,“actual_external_ipv6”:“null”,“router_external_ip”:“null”},
“upnp_autoconfig”: {“status”:“NotFound”}
Anyone knows how to solve this?
Try to enable uPnP in your router. More info in
I still have problems after my router has enabled uPnP
I have contacted my internet provider at the router is now enable to allow ROON arc to work. Since I just had a new fiber box installed and ROON arc worked before - I thought this might have been the issue. But apparently something else is going wring.
Okay I solved it through manual configuration! Excellent!
