I have a Raspberry Pi 4, with the latest version of Verox installed. I’ve had this solution for many years now. However, lately I have found a lot of instability with Spotify Connect and Airplay. The Roon service still works without problem, but the other services might sometimes not be available and other times they stop working after me or my guests has used them to play music on my speakers.
I would love to have a more stable solution, but not sure why these problems occur. Is this a known problem?
I will try to explain the problem as good as I can, and if you have more questions or just fire away and I will do my best to answer them.
For example SpotifyConnect lately hasn’t even showed up as an alternative on Spotify on my iPhone 15 Pro.
Often I can see the Airplay option from Spotify, but after playing a few songs (sometimes changing song before one is fully played) the music stops and I can’t get it to work again.
Thanks! Found it: Spotify Connect and AirPlay are both set to your T+A, but neither was running. In 2026.09.1, if the DAC is switched off while Verox sets up its services (at startup, or when you change a setting), those services are turned off and don’t come back by themselves when the DAC is switched on again. Your T+A came on about 9 minutes after the Pi started, so that’s what happened here. Roon finds the DAC on its own, which is why it kept working.
For now: switch the T+A on first, then reboot the Pi (or open the Services tab and save the Spotify Connect and AirPlay settings again). That brings both back. It’s fixed in the current beta (Advanced → Update Channel → Beta), where they stay on and play once the DAC is back, and it’ll be in the next stable release.
Right: on the beta it doesn’t matter whether the T+A is on when Verox sets up the services. Spotify Connect and AirPlay stay on and start playing once the DAC is switched on. On 2026.09.1 you still need the DAC on first, until the next stable release.
Thanks for the feedback, that helped! Here’s what happened: while switching songs, your T+A briefly reported an error to the Pi. Spotify Connect stopped playing after that, but didn’t let go of the DAC. So every next song failed, and Roon couldn’t use the T+A either, until the reboot freed it.
I’ve fixed that last part: Spotify Connect now lets go of the DAC after such an error, so the next song plays and Roon can take over. The fix goes into a coming beta and into the next stable release.
Until then: if it happens again, a reboot of the Pi (or saving the Spotify Connect settings again under Services) gets everything working again.
