Dear colleagues - I am writing about a phenomenon that worries me very much and is simply annoying, After upgrading to 7.3, both Aries G2 and Vega G2 experience the following issues:
- After a few minutes of playing the track - the cover from ARIES suddenly disappears - as if he wasn’t dragging it from ROON (I have Nucleus). It doesn’t matters if it from file or from Todal or from Qubuz - I attach a picture how it looks. Then I restart ARIES - but it’s annoying.
- Aries - Vega - LEO - are connected with each other by standard HDMI cables, which are added to the set with the purchase. Sometimes Aries stops playing a song for no reason, however I can see the progress of the song on my computer, that the song is playing in ROON. What am I doing then? I switch in DAC VEGA from D-LINK, to, example, COAX - and go back to D-LINK - it helps in most cases. Sometimes, however, you need to restart ARIES. Irritating!
- As recommended - I have Auto Reboot set - once every 24 hours. Unfortunately, once every 3.4 times - LEO doesn’t perform full Auto Reboot - freezes on the startup screen, won’t go any further - why?
These are the 3 most annoying things. Do you have the same? Does it happen to you too? What do you do then?
