Apple Mojave running on a mid-2012 MacBook Pro 2.5 Ghz with 2 TB SSD and 16 MB RAM
ethernet linked dCS Bridge connected to Chord M Scaler and Hugo TT2 in dual BNC mode
See above – the dCS Bridge is linked to the MacBook Pro via AirPlay
Hi Rez files (24/96 and larger in AIFF format) are failing to play longer than a minute or so. The Roon prompt states that they are loading slowly which may indicate a hardware issue. There is currently almost half of the SSD 2 TB capacity filled, so the disk is nowhere close to capacity.
David Street [Email removed by support]
Tue, Oct 22, 4:52 PM (2 days ago)
to Dylan
Hi Dylan,
Yes it was working previously; all of the components in the chain have been rebooted. The problem is still apparent even with an identical MacBook Pro that has exactly the same library content on it. I had noticed a similar but less intrusive problem when both computers were fitted with 1TB SDDs. This seemed to have been resolved by switching to 2 TB SDDs, but has since declined after more Hi Rez AIFF sound files were added to the libraries. I also notice that setting up a queue of 16/44 AIFF files can lead to the same outcome.
