I have a hearing problem. My left ear has a loss of 4db above 2kHz.
I’ve applied a high shelf on the left channel only, using a parametric and procedural eq.
However, in recent weeks Roon is applying this to the right channel as well. I can notice it fairly quickly and turn the right channel off in the dsp settings but it keeps getting turned back on. It happened again today. Is this a bug?
Speaking from general experience but, in this case, specific ignorance: Why not add a perfectly flat filter via parametric/procedural EQs for the right channel? Then, they can both be on at the same time.
Applying the EQ to the left channel was like putting my distance eyeglasses on, having not realized how bad things were without them. It made a significant improvement when listening to my system. Before it was like the mix was panned to about 2 o’clock.
