connection to NAS via LAN
Netgear 10 Gbit Switch, 10 Gbit NAS-Port (Synology Network Card)
Oppo HA-2, USB to Raspberry PI (Ropieee, WiFi or LAN)
Pro-Ject Pre Box S2 Digital to Raspberry PI (Ropieee, WiFi or LAN)
Hifiberry DAC+ Pro (LAN)
audio analysing stops after processing a view hundred tracks (e.q. 476/628326), setting: Fast (7 Cores); after restarting the core it runs again for a view hundred tracks and stops; the same after a complet reboot of the system
There may be a specific track, or group of tracks, that Roon isn’t able to analyze that is holding things up.
I’d like to enable some diagnostics on your account so we can take a look at what you’re experiencing here. Before I do this, may I ask that you please do the following and make a note of the time you do each:
Reboot your Core machine.
Start up Roon and let the spinner go for ~5 minutes.
Reboot your Core machine once more.
Start up Roon and let the spinner go for another ~5 minutes.
This should allow the team to gain some insight into what you’re experiencing in the report. Once you’ve done this let me know the timestamps and I’ll enable diagnostics on your account. When the diagnostics report is uploaded I’ll send it over to our team for analysis.
the “performance” is still unbelievable bad. Whorst: only 2 processed tracks. I´m currently restart the core several times a day. Is there a way for me to find out which files stop the progress?
Apologies for the delay — I’ve asked the team for an update on their investigation here. In the meantime, you can go to Settings > Library and set Background Audio Analysis to Off. With this set to off, Roon does not try to analyze tracks until they’re being played.
I spoke with the team about their findings here. They found that the following tracks appeared to be causing an issue:
\Jazz&Rock&Pop&Soul\b\Brand X\1980 - Do They Hurt\06 - Triumphant Limp.mp3
and
\Jazz&Rock&Pop&Soul\k\Kraftwerk\1972 - Kraftwerk\04 - Vom Himmel Hoch.mp3
Can you send these files over to us via a shared Dropbox link so we can take a look? There may be other files causing issues as well, so we recommend turning off Background Analysis and using only On-Demand Analysis.
