PS Audio DAC (Sr) not seeing "Exclusive" setting
Linux Mint/Sylvia 18.3/Roon 1.7 (build 537)
Linux is connected by Wifi/DAC is directly connected via Ethernet
PS Audio DS DAC
Most often seeing PCM, was able to see DoP from files stored on Linux machine, but haven’t seen input type DSD and am not seeing DSD playback in settings>aduio>advanced to select “native”
I don’t think that the PS Audio can do native DSD via the Bridge II. I would double check with PS Audio tech support. I’ve only found references to “Bridge II can handle PCM resolution up to 32 bit/192kHz, and DSD via DoP”.
Thanks for taking the time! I think you’re exactly right.
From its manual:
“It is possible to send DSD files (without conversion to DoP) over DirectStream’s I2
S inputs as well as USB.”
But like you say, roon is coming via ethernet cable to the Bridge II…not USB, etc.
Thanks again! I’m learning tons.
