Mac OS Catalina vers. 10.15.2
Roon Vers. 1.7 build 511
PS Audio Direct Stream DAC with bridge
I am trying to get my HD Qobuz music to play in HD. When I go to Settings in Roon and then to Services and then press the edit tab next to Qobuz a window opens with the Streaming Quality options. Herein lies the problem issue. The only options that show up are CD 16Bit/44.1kHz and MP3 320 Kbps. HD options are nowhere to be found.
Thank you in advance for your help.
