OS: Ubuntu 22.04.1 LTS
HW Description:
H/W-Pfad Gerät Klasse Beschreibung
system MZGLKAP-00 (01)
/0 bus MZGLKAP-00
/0/0 memory 64KiB BIOS
/0/28 memory 4GiB Systemspeicher
/0/28/0 memory 4GiB SODIMM DDR4 Synchron 2133 MHz (0,5 ns)
/0/28/1 memory DIMM DDR2 Synchron [leer]
/0/35 memory 224KiB L1 Cache
/0/36 memory 4MiB L2 Cache
/0/37 processor Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
/0/100 bridge Gemini Lake Host Bridge
/0/100/0.3 generic Celeron/Pentium Silver Processor Gaussian Mixture Model
/0/100/2 display GeminiLake [UHD Graphics 600]
/0/100/e card0 multimedia Celeron/Pentium Silver Processor High Definition Audio
/0/100/e/0 input2 input HDA Intel PCH Headphone
/0/100/e/1 input3 input HDA Intel PCH HDMI/DP,pcm=3
/0/100/e/2 input4 input HDA Intel PCH HDMI/DP,pcm=7
/0/100/e/3 input5 input HDA Intel PCH HDMI/DP,pcm=8
/0/100/e/4 input6 input HDA Intel PCH HDMI/DP,pcm=9
/0/100/e/5 input7 input HDA Intel PCH HDMI/DP,pcm=10
/0/100/f communication Celeron/Pentium Silver Processor Trusted Execution Engine Interface
/0/100/12 scsi1 storage Celeron/Pentium Silver Processor SATA Controller
/0/100/12/0.0.0 /dev/sda disk 256GB INTEL SSDSCKKF25
/0/100/12/0.0.0/1 /dev/sda1 volume 511MiB Windows FAT Laufwerk
/0/100/12/0.0.0/2 /dev/sda2 volume 237GiB EXT4-Laufwerk
/0/100/13 bridge Gemini Lake PCI Express Root Port
/0/100/13/0 wlp1s0 network Dual Band Wireless-AC 3168NGW [Stone Peak]
/0/100/13.3 bridge Gemini Lake PCI Express Root Port
/0/100/13.3/0 enp2s0 network RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
/0/100/15 bus Celeron/Pentium Silver Processor USB 3.0 xHCI Controller
/0/100/15/0 usb1 bus xHCI Host Controller
/0/100/15/0/3 communication Wireless-AC 3168 Bluetooth
/0/100/15/1 usb2 bus xHCI Host Controller
/0/100/1c mmc0 bus Celeron/Pentium Silver Processor SDA Standard Compliant SD Host Controller
/0/100/1e mmc1 bus Intel Corporation
/0/100/1f bridge Celeron/Pentium Silver Processor LPC Controller
/0/100/1f/0 system PnP device PNP0c02
/0/100/1f/1 communication PnP device PNP0501
/0/100/1f/2 system PnP device PNP0c02
/0/100/1f/3 system PnP device PNP0c02
/0/100/1f/4 system PnP device PNP0b00
/0/100/1f.1 bus Celeron/Pentium Silver Processor Gaussian Mixture Model
/1 input0 input Power Button
/2 input1 input Video Bus
Fritzbox Mesh Network. Current Release 7.50.All devices connected via LAN
NAD M10 v2 via LAN
RME ADI-2 DAC FS via analog input
HiRes recordings from Qobuz with 88.2 kHz 24Bit 2ch. do not work. Example: Open Qobuz
Every other combination works fine including Tidal FLAC 44.1 kHz 24bit, MQA 88.2 kHz.
My NAD 10 v2 plays the same track via BluOS without a problem.
Ok, 88.2 kHz are quite rare, but I would still like to know what the reason is that they do not run.
Greetings from Germany
Ralph
