Qobuz Playlist problem
Is there a reason why I cant save a track in Qobuz to a playlist that is already listed in My Stuff? If I try, I only get the option to start a new playlist, I cant add it to one thats already there…
Thanks.
Hi, its a list on Qobuz. Do they have to me made originally on Roon?
Thanks for your help.
Yes my Qobuz lists show in Roon but I cant add tracks to them directly in Roon, is this the same for you?
You need to save a Qobuz Playlist as a local copy in Roon before you can add to or edit the Playlist copy…
Geoff your a star! Thank you. And thanks Menzies for your help too. I just knew it would be operator error… :wink:
Of course you now have two near duplicate playlists appearing in the Roon interface, yet any changes you make to the local copy you just created won’t be reflected back in Qobuz.
Seriously Roon’s external playlist support is long overdue some TLC.
:person_shrugging:
Oh, yes your right. Would it be better with Tidal?
No, same problem
ok thanks.
I just add my local copy into my Playlists in my library - I do nothing further with the Qobuz Playlist. As far as I am concerned the Qobuz Playlist is part of the Qobuz streaming universe, my local copy in my Library is the important example (to me).
