I’ve just finished installing my Roon Core on My NAS (QNAP TS251+). It plays my locally stored files fine, but will not connect to my Qobuz account. I get the same message no matter what Qobuz track I try to access. “Unable to start streaming. Check your Qobuz account and try again”.
I changed the core over to my PC and have no trouble accessing Qobuz or my local files.
I’m assuming that the issue may be firewall / port related, but would love any guidance on getting Qobuz access through my NAS as the core.
Just to confirm — The same exact Qobuz account is being used for both Core machines? If you login to the Qobuz webplayer from this account are you able to play Qobuz content beyond just 30-second demos?
Thanks for the fast contact BTW. To be more helpful, here is my setup.
QNAP NAS TS 251+ Running QTS 4.4.1.1146. Roon Server " Version : 1.7 (build 505) stable QPKG-Version : 2019-06-09 Process ID : 14361"
INternet access is into Linksys EA9500 as modem/router. NAS is wired ethernet to the EA9500
Currently accessing the NAS core through my PC, also hard wired ethernet to the same EA9500.
