RAAT Problem In Core Mode 2012 R2
“The exception unknown software exception 0xe0434352 occurred in the application at location 0x069f8a5c”
This is what I am getting when I start Server 2012 R2 in Core Mode. It runs fine in GUI mode.
Obviously not a priority at this time for you guys, but if there is a simple fix or could look into it a sometime it would be greatly appreciated.
Can you try following the instructions here? Let me know if that doesn’t take care of it and we can take a deeper look.
Thanks and sorry for the trouble!
Tried that. Still get the same issue in Core Mode of Server.
I’m trying to run RoonBridge on WinSrv2012 R2 Core mode.
On GUI mode, it runs properly (boot RoonBridge at Logon Script) .
But after switched to Core mode, RAATserver shows following error when Windows booted and I (Administrator) logged on (of course, it doesn’t runs).
“The exception unknown software exception 0xe0434352 occurred in the application at location 0x2a238a5c”.
I tested above “the instruction here”, but that installation failed.
Is RoonBridge not compatible with Core mode ?
If it’s compatible, please tell me how to setup it.
Regards.
