Since the last update to 1.4 build 310 the automatic Radio feature is no longer working. My selected music comes to the end and nothing continues after.
It was working ok on 306.
A couple of questions. Is Radio set to Yes, so that it will start after your queue is empty?
Also, are you playing Tidal tracks that have been added to your library? Radio will not start if the last track is a Tidal track that hasn’t been added to your library.
