With the upgrade to 3.094 the dragonfly attached to the usb is no longer recognized as an audio zone. Spotify connect and airplay work without issues through the dragonfly. I reflashed the player but it did not fix. Any ideas for me to try?.
Go to settings and deactivate the dac and then reactivate it. My dragonfly red is working fine.
Cheers
Christian
It seems to be linked to the wifi setup, it all works fine when wired, when I boot wireless it gives a “bad value for ‘hidepid’ message and it doesn’t boot until I wire
