hi
usbridge is working fine with the new dietpi gui image 6.1
ok i like to get spotifyconnect running…
i installed over ssh in dietpi-software “raspotify”
after a reboot i lost the usbridge with the Amanero lks004. here is the solution from MichaT @ computeraudiophil
This is what I was advised to do:
SSH into diet pi and check the uEnv.txt file
The command = nano /DietPi/uEnv.txt
Check the end of the second line of the text file. I had to scroll along manually to do this. You are looking for “aotg.aotg1_speed value”. The speed value needs to be set to 0 for 32 bit USB 2.0 DACs like my Mojo. If you’re using a dragonfly or other USB 1.1 DACs it should be set to 1. The last line should look like this… $d/systemd aotg.urb_fix=1 aotg.aotg1_speed=0
Exit and save the file then reboot the system. You should then be back in business!
this is working
now i need to configure raspotify and i need some help.
at ssh wit aplay -L
i get the name from my card…
"dmix:CARD=Amanero,DEV=0
Combo384 Amanero, USB Audio
Direct sample mixing device
dsnoop:CARD=Amanero,DEV=0
Direct sample snooping device
hw:CARD=Amanero,DEV=0
Direct hardware device without any conversions
plughw:CARD=Amanero,DEV=0
Hardware device with all software conversions
root@DietPi:~#
now i think my usb card is Amanero
so i changed the name in ssh with
nano /etc/default/raspotify
OPTIONS=“—device plughw:Amanero”
and no # at the beginning
------i don´t know if i need to put my spotifyname and password for the 320 option? please clarify.
ok i can see the raspotifydevice but no music.
plz help
i don´t know exactly what you mean…allo usbridge with dietpi GUI image 6.1 . USB-port from the bridge is connected to an lks004 with combo amanero.
Spotify runs on different devices -ios and osx
thanks…still no sound
maybe its the bit-depth`? Amanero needs 32? in shairpoint and squeezelight i had to change it over the GUI to bring it to life…
thanks
great answer from dietpiforum…
copy paste mistake…"-" instead of “–”
by Facel@dietpi…
You have to
issue the command aplay -l
Note the name of your Dac in the output of aplay -l
edit the config file by the command nano /etc/default/raspotify
change the speed from 160 to 320
add a line as follows
OPTIONS=“—device plughw:dacname”
(on your screen shot it seems thate there is written “-device …” instead of “–device …”
substitute dacname with the name you noted with aplay-l command
Save your changes and exit nano.
Issue the command systemctl restart raspotify
I type it as two - characters. Don’t know what you typed. If it were me I would have copy pasted my text rather than typing afresh. Does it work now? The clue is also in the config file comments!
