TP-Link Deco M9
iPhone and iPad cannot remote connect to Nucleus+ but if type the Nucleus+ IP address, I can see the system status screen. Another PC and iMac have no problem by using same wifi to have remote connection.
No, I didn’t update the iOS s/w. The situation actually getting worse. After I power cycled, the Nucleus seems no longer working. I connect it to monitor via HDMI cable, it will not boot up like before has the roon screen and monitor show cannot detect signal. It only worked 2 days since I purchased…I purchased if from Amazon. Should I have a replacement? Thanks!
Hello @Huihao_Hung, does your windows device have network discovery turned on? Can you provide a screenshot of what happens when you try to enter smb and your credentials?
I returned the problematic one since it eventually cannot boot up. After I got the new one, everything looks good except I cannot use smb://NUCLEUSPLUS/Data but if I use IP address smb://192.168…it works fine.
