All of my Roon endpoints are experiencing the same issue, they are all waiting to connect to the Roon core - and never connect. I have my Roon core on a QNAP. Here is the dump I get:
15.01.18-20:49:02 --- writing to log: System.UnauthorizedAccessException: Access to the path "/share/external/DEV3304_1/RoonServer/Logs/RoonServer_log.txt" is denied.
15.01.18-20:49:02 --- at System.IO.FileStream.FlushBuffer () [0x00081] in <6dd476c5e2524b8eb9012b2c79d48862>:0
15.01.18-20:49:02 --- at System.IO.FileStream.Flush () [0x00018] in <6dd476c5e2524b8eb9012b2c79d48862>:0
15.01.18-20:49:02 --- at System.IO.StreamWriter.Flush (System.Boolean flushStream, System.Boolean flushEncoder) [0x00094] in <6dd476c5e2524b8eb9012b2c79d48862>:0
15.01.18-20:49:02 --- at System.IO.StreamWriter.Flush () [0x00006] in <6dd476c5e2524b8eb9012b2c79d48862>:0
15.01.18-20:49:02 --- at Base.StreamLogWriter.WriteLine (System.String s) [0x0001d] in /home/roon/roon/Base/logging.cs:207
15.01.18-20:49:02 --- writing to log: System.ObjectDisposedException: Cannot write to a closed TextWriter.
15.01.18-20:49:02 --- at System.IO.StreamWriter.Flush (System.Boolean flushStream, System.Boolean flushEncoder) [0x00008] in <6dd476c5e2524b8eb9012b2c79d48862>:0
15.01.18-20:49:02 --- at System.IO.StreamWriter.Write (System.Char[] buffer, System.Int32 index, System.Int32 count) [0x00078] in <6dd476c5e2524b8eb9012b2c79d48862>:0
15.01.18-20:49:02 --- at System.IO.TextWriter.WriteLine (System.String value) [0x00070] in <6dd476c5e2524b8eb9012b2c79d48862>:0
15.01.18-20:49:02 --- at Base.StreamLogWriter.WriteLine (System.String s) [0x00011] in /home/roon/roon/Base/logging.cs:206
15.01.18-20:49:02 --- Error
15.01.18-20:49:04 --- Initializing
15.01.18-20:49:04 --- Started
15.01.18-20:49:05 --- Not responding
15.01.18-20:49:10 --- Running
I have absolutely no idea what any of this means, can someone help me decipher?
