Rock on nuc 5i3RYHS, version 1.7 build 667
Vodafone WiFi hub model THG3000
Ethernet connection
Roon Bridge - Ropieee v1.7 build 571
Hi, a few days ago rock updated to build 667 and since then I am having a problem using the remote roon app on my amazon fire HD 10 tablet.
I can’t get it to connect after it has been idle for a few hours and only after fiddling around with rebooting Rock, turning WiFi on and off etc I then get it to connect and it’s fine for a few hours.
I have tried reinstalling the app, turning router on and off, and a few other bits but the problem persists.
Incidentally I noticed the ip address for rock and Ropiee are different? If that helps?.
Kind regards.
