You can log into the QNAP by going to Roon Settings -> General -> Disconnect. On the “Choose your Core” screen, you can select the active Core, and you should be presented with an “Unauthroize” page if you already have designated one Core. You can feel free to switch between Cores as often as you’d like, but you are limited to one active Core at a time.
Just to clarify, you weren’t using the QNAP as a remote here, it was just logged in? And the crashing behavior only started following the reboot?
When the QNAP is in this crashing state, does anything change if you unplug the Ethernet cable? Logs should note if the crashing still happens or if it temporarily stops with the Network removed.
I don’t how to open a remote on the QNAP. What I did is, I restarted the RoonServer on my Windows PC and deactivated with a remote (iPAD) the RoonServer ont the Windows.
Yes, I am not aware of a QNAP remote tool. Did I miss something?
Will test this later in the week.
I can deactivate the RoonServer on Windows and then activating the QNAP RoonServer and I get the Networkerror and after that the RoonServer goes into crash loop. I wonder waht changed between this build (511) and the previous one. Is there a possibility to get the previous build for QNAP?
Unplugged the Ethernet cable, the logs later show that the crashing just goes on.
In the meanwhile I installed the RoonServer from here: https://kb.roonlabs.com/LinuxInstall. But I get the same problems as with the QNAP package. In the logs I saw more info and I found this post: Terminate called after throwing an instance of 'OpenHome::NetworkError' which exactly shows the same effect. In the next day I will look a bit more in that post. It seems to be a problem with the mono app, which is also used by Emby (which is running on this QNAP).
Shutting down the EMBY server makes ROON happy and I can use it. The solution is to start first ROON and than EMBY.
