Brand new ROCK build, NUC10i7FNHN1, 128 SSD, 8 GB RAM
Version 1.8 (build 831) stable
Remotes: iPhone X Pro, iPhone XR, Windows 10 XP, iPAD 9th Gen
(All on current Roon software)
Music files on an old Synology NAS DS212.
Netgear Orbi Mesh Router: RBR50/RBS50
Netgear Ethernet Switch GS-108
ROCK Core is plugged directly into the router
Using Tidal and Qobuz to stream
Main system streams to LUMIN D1 in Roon Ready Mode, WIFI backhaul connection
Also have Sonos, both S1 & S2 components, using sonosnet with either a wired boost or wired streamer.
Approximately 3000 tracks in library
I am brand new to Roon, in fact just finishing up my trial membership. I’ve been running Roon on a dedicated seven-year-old ThinkPad without issues. I just purchased a NUC, installed ROCK on it and migrated the database. All seemed good at first, then we started having lock-ups and problems streaming Qobuz.
In the process of troubleshooting those issues (still unresolved), I unplugged and rebooted all of my network devices in the appropriate order. After that, I was no longer able to connect to the ROCK core. I could still connect to the old Thinkpad Core.
So, I went digging around in the logs and discovered that the ROCK core was circling around trying to connect to my NAS, which I had forgotten to turn back on. Here are the logs showing the issue. It just kept circling around trying to connect to the NAS.
Once I turned the NAS back on, I was able to connect again. This is concerning. The Thinkpad Core was smart enough to move on and connect without the NAS connection. Can this be fixed? What if my NAS breaks? Would I have to rebuild my CORE?
I’m still working on the other issues but thought it worthwhile to get this sorted out first. Thanks in advance for your help.
Section from log that kept getting repeated:
10/25 21:10:42 Warn: [roon/cifs] failed to connect to CIFS storage: mount error: could not resolve address for diskstation: Unknown error
10/25 21:10:42 Info: [broker/filebrowser/volumeshare] Volume's CIFSMount's availability changed: False
10/25 21:10:42 Debug: [broker/filebrowser/drive] availability on drive's volume changed: False: VolumeShare[networkpath:\\diskstation\sonos,mountdir:<null>]
10/25 21:10:42 Info: [broker/locations/directorystoragelocation] drive availabilitychanged: False, FileBrowser.Entry: \\diskstation, sonos : \ (it was False)
10/25 21:10:47 Debug: [roon/cifs] tryremount, path: \\diskstation\sonos, username: music, password 9 chars
10/25 21:10:47 Debug: [roon/cifs] mounting \\diskstation\sonos
10/25 21:10:47 Debug: [roon/cifs] alreadymounted? //diskstation/sonos => false
10/25 21:10:47 Debug: [roon/cifs] cleaning mount points: /roon/sys/storage/smbmounts/RoonStorage_*
10/25 21:10:47 Debug: [roon/cifs] domount: PASSWD="******" /sbin/mount.cifs "//diskstation/sonos" "/roon/sys/storage/smbmounts/RoonStorage_c5e2d51e625047f9328ce6e8e2296ca2a097a8f7" -o guest,nounix,iocharset=utf8,user="music",domain="WORKGROUP",vers=2.1
10/25 21:10:48 Debug: [roon/cifs] returned 1: mount error: could not resolve address for diskstation: Unknown error
10/25 21:10:48 Debug: [roon/cifs] PASSWD="******" /sbin/mount.cifs "//diskstation/sonos" "/roon/sys/storage/smbmounts/RoonStorage_c5e2d51e625047f9328ce6e8e2296ca2a097a8f7" -o guest,nounix,iocharset=utf8,user="music",domain="WORKGROUP",vers=2.1 failed: (1): mount error: could not resolve address for diskstation: Unknown error
10/25 21:10:48 Debug: [roon/cifs] domount: PASSWD="******" /sbin/mount.cifs "//diskstation/sonos" "/roon/sys/storage/smbmounts/RoonStorage_c5e2d51e625047f9328ce6e8e2296ca2a097a8f7" -o guest,nounix,iocharset=utf8,user="music",domain="WORKGROUP",vers=2.0
10/25 21:10:48 Debug: [roon/cifs] PASSWD="******" /sbin/mount.cifs "//diskstation/sonos" "/roon/sys/storage/smbmounts/RoonStorage_c5e2d51e625047f9328ce6e8e2296ca2a097a8f7" -o guest,nounix,iocharset=utf8,user="music",domain="WORKGROUP",vers=2.0 failed: (1): mount error: could not resolve address for diskstation: Unknown error
10/25 21:10:48 Debug: [roon/cifs] domount: PASSWD="******" /sbin/mount.cifs "//diskstation/sonos" "/roon/sys/storage/smbmounts/RoonStorage_c5e2d51e625047f9328ce6e8e2296ca2a097a8f7" -o guest,nounix,iocharset=utf8,user="music",domain="WORKGROUP",vers=1.0
10/25 21:10:49 Debug: [roon/cifs] returned 1: mount error: could not resolve address for diskstation: Unknown error
10/25 21:10:49 Debug: [roon/cifs] PASSWD="******" /sbin/mount.cifs "//diskstation/sonos" "/roon/sys/storage/smbmounts/RoonStorage_c5e2d51e625047f9328ce6e8e2296ca2a097a8f7" -o guest,nounix,iocharset=utf8,user="music",domain="WORKGROUP",vers=1.0 failed: (1): mount error: could not resolve address for diskstation: Unknown error
10/25 21:10:49 Debug: [roon/cifs] Mount deleting: /roon/sys/storage/smbmounts/RoonStorage_c5e2d51e625047f9328ce6e8e2296ca2a097a8f7
