Edu
Rebooting the Roon Core usually clears the duplicates out for a while.
I have seen other user’s complain about this, but I have not seen it myself.
Hello Michael
This helped . I now only have 2 occurrences for each Sonos Symfonisk (IKEA Sonos speaker) . One for Airplay-streaming and one for Sonos-streaming . It seems that only one of them has to be activated in Roon, I think ?
Edu good news there.
I disable the AirPlay in my environment, and Some people disable the SonosNet ones. It is easier to stick with one and less confusing, so I would recommend disabling the one you don’t want to use.
Hey @Edu_Schol,
Thanks for sharing some details about your setup and the questions you had. It looks like @Michael_Harris had a moment to help out - thanks a bunch!
Did this solution work for you, @Edu_Schol ?
