I now cannot create a backup either manually or automatically.
Been running fine until 1.8. Now I get an automatic backup failure report.
When I try to run a manual backup, I get there was an issue loading your database, forcing me to restore last backup from 9th Dec.
Then I have to rebuild the databse due to a new version has been installed.
Once the backup has been restored then rebuilt it is ok, until it either trys to run an automatic backup and fails or I try to run a manual one. Then I get the same error ^^ (rinse and repeat)…
I have reinstalled the OS as well and bug still exists.
