Hello,
Can you tell me if the RME ADI-2 Pro using Roon I can adjust the volume control with Roon? I only want to use this dac for 2ch playback and use its DSD capability.
manual
Hello,
manual
Can anyone help?
Hi @jtwrace ---- Thank you for you patience.
In regard to your question, if the device exposes standard USB Audio 2.0 volume controls, it should work.
-Eric
This is basically USB HID volume control you are talking about, right? I’m also wondering the same question. I asked on the CA forum and Miska said he thought not but didn’t sound 100% sure. The OP… did you ever find out the answer for sure?
I asked on the RME forum and was told it doesn’t support USB HID control i.e. “Device Controls” in Roon. Which is a shame as am a big fan of USB HID control and the RME looks like a great unit otherwise.
