…simply put, a dns server can die and industry standard is to have at least 2 dns server entries in the network settings…One of my dns did indeed die hence the pain when the family is using Roon …
In the mean time, just hard code 8.8.8.8 or 1.1.1.1 in your Rock, and all good.
actually you can put 3 if you want as I do…but I think you need to also use a fixed IP address so make sure you have a non DHCP allocation available.
