Asus rt66u/ ethernet
HDMI to Monitor.
Followed according to the instructions.
Updated BIOS to ver.0080
Removed the UEFI download
Removed the download over the network and put the download on the USB priority.
I inserted a USB flash 8GB into the front USB 3.0 slot with pre-loaded roon rock through Balena Eather
When downloading, press f10 and select download from USB
Installed roon following the points in the bootloader. I chose the installation on m.2 ssd.
Next, the bootloader asked to remove the USB flash drive and reboot the system.
After the reboot, a black screen appears with a flashing dash in the left corner, and after 4 minutes it says: “Rеbооt аnd Ѕеlесt рrореr Вооt dеvісе оr Іnѕеrt Вооt Меdіа іn ѕеlесtеd Вооt dеvісе аnd рrеѕѕ а kеу”.
Also, the device does not appear on the network
What could be the problem? What could I miss?
Not. After installation, I remove the USB flash drive before rebooting, and apart from the m.2 drive, nothing else is installed. I tried even after rebooting to press F10 and select the boot from ssd manually.
Or maybe there is a problem in the m.2 drive? Strange PCIe x4 lanes model (samsung mzhpv128hdgm). It is neither SATA nor NVME
Bios sees my disk m.2. Priority downloads comes first. Nevertheless, the format of the m.2 disk itself also confuses me. Today I will buy the usual m.2 SATA and test it. Tell me, can there be a problem with the new version of BIOS? Have you had experience installing ROON ROCK on BIOS version BN0080?
I bought a new disk format SATA. The system booted perfectly. The problem was that most likely the roon rock system does not accept non-standard disks, like my Samsung was. . Thanks to all.
