I’m testing ROON on PC (Windows 10) with my Squeezebox (Duet Receiver). No problem, Squeezebox will be recognized and works great!
Then I bought a NUC7i3BNH and I installed ROCK Version 1.6 (build 416) stable.
The problem: ROCK does not recognize Squeezebox! (My Auralic Aries mini in the same network is recognized and it works great.)
- LMS is uninstalled
- NUC and Squeezebox are on the same switch
- I changed again to ROON on PC: Squeezebox is recognized
- I changed again to ROON on ROCK: Squeezebox is NOT recognized
How can I solve this problem? I want to buy ROON at the end of the trial, but the problem with the squeezebox has to be solved.
Best regards
Michael
