Just prepare the image on the USB drive, and the installation process will format both disk, and ask which one is for the Roon database, and thatâs it.
In most cases, the internal drive is empty so the computer will default to USB. During Boot, I think if you press F10 it will bring up the boot menu and you can then select the device to boot from.
Theres 8Gb Ram and a 256Gb m.2 board I think, I will add a ssd to rip my cd collection onto which I think, from reading support info on the site, the Roon Rock installation will support
How many CDs are you talking about? While you CAN rip a CD via ROCK, I wouldnât want my whole collection of CDâs ripped that way. You end up with a whole bunch of files with generic names (Track1.flac, Track2.flac) in folders with names like âCD-Ripped-2019-08-02â18-19-47â.
Everything appears fine in Roon, which is nice. But if you are going to rip a large number of CDs it would make sense to use something like dBPoweramp (or even iTunes) to end up with something thatâs transportable. What are you going to do if you want to bring music to your car, or phone?
Hello. I hadnt realised that, and I have a fair number. Havenât heard of dBPoweramp, so will have a look - I guess this rwould equire an additional storage drive being set up.
You can use Roonâs Export function to export your selected albums/tracks to a staging folder. All the basic metadata will be added, and renaming of the folders/tracks to artist/album and track titles done automatically by Roon.
So youâll need roughly 300*500 = 150GB of drive space for those. Double that to future proof it and it would fit on a modern SSD hard drive.
Bear in mind you really donât need the speed though. I would possibly use a USB hard drive or a NAS (mine is in the cellar, so no noise).
I would also rip straight to the USB using something like dBPowerAmp or XLD (Mac OSX). These will prepoulate the metadata in the vast majority of CD rips. I started with Sooloos and learnt from experience it was worth getting the metadata right from the off, with consistent naming and tagging. It saves a lot of time later on.
Well, really all you need on the âripping computerâ is enough space to store the discs you ripped in a batch. Then you could move them over to the NUCâs internal drive.
That said, any solution here should include a backup strategy, as you are now investing a lot into the process. So a USB drive of some sort would be important anyway.
Windows wIll have more ripping options for sure and will run your library just fine on that Nuc.
You can rip in windows or Mac if you have another computer. Rock doesnât allow anything other roon to run but the ripper is really just for the odd disk
