I unplugged my NUC with ROCK and plugged it back in. While my network then found the NUC at the usual IP address and I got the ROCK software to come up by visiting the IP address through a browser, Roon couldn’t recognize it. I rebooted the network, etc., but it still couldn’t find it. I even updated the Roon OS.
I then followed the troubleshooting steps and had Roon on my Mac try to find a different core. It then found my ROCK, and I connected to it, but now my library and all my settings (such as audio devices to play the music) have disappeared. I’m not sure whether I accidentally swapped in a new NUC.
In any event, I had been backing up my Roon library to my Mac. Is it possible to restore my library and all settings? I really hope I don’t have to redo the ARC settings, as they are tricky.
Thanks.
Thank you.
Is Roon Server running?
· "Waiting for your Roon Server"
What happens if you press the "Select a different Roon Server" button?
· I don't see Roon Server.
Please try to restart your Roon Server by closing the Roon app in the taskbar or rebooting your Roon Server machine.
· *Roon Optimized Core Kit* (ROCK)
ROCK Core disappeared after NUC unplugged
Ubiquiti Network with UDM Pro and 24-Pro and 16-lite switches
