When are you releasing an update of Roon OS to be compatible with current bios and NUCs?
I am using a NUC8I5BEK for some time now and updated to latest firmware (90) today. But with this BIOS version Roon doesn’t boot anymore. So had to do a BIOS recovery back to 89 to get it working again.
It’s time to release an update of the OS platform don’t you think?
So what I could try is to enable UEFI in Bios, disable legacy and do a reinstall of Rock and a restore from backup to enable everything again?
I thought Roon OS wasn’t compatible with UEFI at this moment?
When I do a reinstall of the OS it says 1.0 (254) is this current version for UEFI?
Or is the right OS version only installed with a full reinstall of ROCK?
I confirm.
Smoothly updated ROCK to build to 254, but after BIOS update NUC didn’t boot.
I had to enable UEFI boot in BIOS (left legacy boot enabled either) and install ROCK from scratch.
Correct – legacy boot ROCK will update to 254, but we no longer provide installers for legacy boot. It just makes things too confusing, especially for new users.
