New install Rock Os 1.8 on to NUC i7.
Installation went well and the Roonserver is running but in the setting > audio, all the other Devices are missing like Amanero Combo 384 after 5secs
Any ideas?
I also don’t see the NUC/ROCK on the list. Does it show up in settings/about? If you had a core on your MAC did you make sure to switch to the core on the NUC/ROCK?
I’ve ran backup to restore the settings but the “Amanero Combo 384” shows up for 10s then if you enable it.
The Audio setup devices disappear like in the first image.
Any ideas?
The issue is that I had to restore from backup then the Audio setup displays other devices to be enabled.
Has soon I enable Amanero Combo 384 - enabling then it disappears.
For the Amanero Combo384 (which is a USB to I2S converter as far as I can tell from looking at the data sheet), looks like it has specific triggers it is looking for to activate. You may need to contact the OEM dealer or manufacturer for help.
Is the Lampizator connected directly to the NUC? or to the MacBook? In either case you may need to look at your security settings (firewall, etc) to see if Roon and RAATserver processes are allowed to pass through? On the Macbook you should be seeing a “this Mac” section in settings/audio. If not there are probably issues with the security settings.
There are several threads related to this issue. doing a search on the forum for “no audio devices mac” will get you results to look in to.
That’s a good idea - because it’s a new NUC with a new SSD and RAM. no pre-installed OS.
Maybe USB DAC drivers are not installed for NUC.
I’m trying to get Audio-linux to work with it and update you?
My 2nd report was due to no resolution for the first ticket.
I’ve replaced my old NUC with this New install Rock Os 1.8 onto NUC i7.
Installation went well and the Roonserver is running but in the setting > audio, all the other devices are missing.
Unable to setup any USB DACs
Maybe the license or the Roonserver configuration has a conflicting issue because I replaced HW.
Any ideas?
Thanks for getting in touch with your report, we’d be happy to help.
As @bearFNF indicated, it doesn’t look like your Core is running on your NUC, it appears to still be on your Mac. Please go to Settings>About and post a screenshot so we can take a closer look. You should see the Mac as your remote, and your NUC as Core.
We’ll be watching for your reply and get back to you as quickly as we can.
