NUC8i7BEH - about to receive and set up.
Just wifi for database/updates/remote on android .
Oppo UDP-205 via USB.
I am about to set up ROCK on a NUC. My Core is currently on a laptop and my library is external on a 2.5” SSD (exFAT) in a SATA to USB enclosure.
My question is, once I have set up ROCK and have it running using the external library via USB as above, can I then re-mount the 2.5” SSD as an internal drive in the NUC without ROCK still wanting to re-format it when it sees it ?
The ROCK installation advice doesn’t say you can do this, but it doesn’t say you can’t, either.
