Audio output has been Chord Hugo MScaler and worked for > 1 y previously. Can no longer discover MScaler (it is powered on and entire audio and computer system have been rebooted twice) after using MScaler connected to Innuos Zenith SE via USB. The Innuos Zenith SE is the core and is recognized by Roon in Setting/General.
Not sure how to set this up when the device is not discovered in Setting/Audio. Seems like this automatically happened before, but I would appreciate suggestions on how to regain access to my primary listening system via Roon.
At 1403 CDT Chord appeared again. I did nothing in addition to what I described above. Head scratcher. Thank you both for responding. Did you folks do something remotely, Dylan? The Roon version has not changed.
Despite intermittent appearance of Chord in Audio settings, I’m not able to consistently listen. Getting message “Roon Lost Control of the Audio Device”. I’ve checked all connections in the chain and none are loose or damaged.
