I have enabled diagnostics on your account so our technical staff can get some more insight into what’s going on here. The next time your Core is active a diagnostics report will automatically be generated and uploaded directly to our servers
Hello @Joop_Seters, I spoke with the QA team recently and I’d like to have you try and open Roon on your core while it’s disconnected from your network. Please let me know if Roon opens when disconnected, if it does, please let me know what smart devices you have on your network, thanks!
I uncabled my router and started Roon but it did not open. In the log I see 5 critical messages which concern the absence of a internet connection.
And the same critical message as before:
Hi, I already tried the following (a number of times):
Uninstall Roon with library
Restart PC
Install Roon without restoring, just login to Roon
(see my post December 2nd)
This does not solve the problem
Hi, any progress on my topic?
To me it seems that Roon has a problem with the latest regular Windows 10 update and more users have this problem. I hope you can investigate this as one problem instead of unrelated ones.
Is Roon tested against Windows 10 and its updates?
An update on my problem. A week ago my system (Dell Alienware) informed me of an update for my system. Without looking at the contents of the update I clicked on install update. After the necessary reboot the first thing I did was installing Roon again and to my pleasant surprise Roon worked again.
Somehow the Alienware update solved my problems. I’m sorry that I cannot say what part of the update solved it. I have been using Roon for a week now without any problems.
You can close this ticket. Maybe others with simular problems and a Dell system can solve it with an update from Dell.
