It is not possible to add a track to existing playlist. The list is empty:
Hi @Nabob,
Are the playlists in your library made in Roon, or were they imported from somewhere else?
If you make a New Playlist does it work?
I know it is not possible to add to playlists generated in Tidal, so I am thinking about playlists created in Roon.
It is possible to create a new playlist in the popup window, and the created playlist is also visible when I want to add another track. But I really need to add tracks to my existing playlists created pre 1.8.
Thanks.
I can now see all my Roon created playlists when adding a track with build 756.
Thanks.
