Windows 10 Pro 20H2 19042.746/Dell OptiPlex 7050MFF, i5-7400, 16GB, Samsung PM961 NVMe 500GB (only OS and Roon running), Roon Server 1.8 (build 753), headless device with no audio connection
Hardwired gigabit ethernet HP ProCurve 1810g-8 Switch
Antelope Dicrete 4 Synergy Core connected with USB to MacBook Pro (mid 2012) i5/8GB/500GB SSD Catalina 10.15.7
Mytek Brooklyn connected to Dell Precision 5530 workstation Xeon/32GB/500GB NVMe, Win10Pro 20H2
(Other devices on network include Kef LS50WII on chromecast, PC with roon bridge connected to Meridian Explorer 2)
Two major issues both on the Mac and the PC:
Even though enabled, the local audio devices can not be connected to, are not listed on the zone list. Tried enabling all available devices (default system out, on board sound card, wasapi drivers) and the result is the same. Both devices only see the Kef LS50WII and RoonBridge device on the zone list. They can’t see even local devices.
The Mac and the PC can connect to the Kef and teh roon Bridge PC but there is a behavior problem: You are able so start playing but after that the controls don’t work and time cursor does not advance. You can choose another song to play but again can’t stop from the controls, basically the controls are useless.
Need you help!
Yaman
