Hello Everyone,
The primary change in this week’s earlyaccess release is an update of the development framework used by Roon and RoonServer on the Windows platform to Microsoft .NET 6. This change should have no impact on the behavior or performance of Roon on Windows so if you notice anything out of the ordinary please let us know ASAP.
There are a number of additional fixes in this release as noted in the changelog below which address some isolated issues which popped up in last week’s production release.
Thank you for your continued support,
The Team at Roon Labs
What’s new in this release?
Build Numbers
| Application | Version |
| Roon / RoonServer | 2.0 (build 1216) earlyaccess |
| Roon ARC | 1.0 (build 149) earlyaccess |
| Roon Remote (Android / iOS) | 2.0 (build 1216) earlyaccess |
Changes
- Roon and RoonServer for Windows are now based on .NET6
- Fixed a bug where custom genre tags were not displaying correctly
- Fixed a bug in which metadata was incorrect on some internet radio stations
- Fixed a bug with search autocomplete results which caused clicking on “see all” to fail
- Numerous minor fixes and performance improvements
Installation
Cores, remotes, and ARC installations already running earlyaccess should update automatically. If you need to reinstall, the latest earlyaccess builds can always be found at the following links.
| macOS: | Roon | RoonServer |
| Windows: | Roon | RoonServer |
| Linux: † | Easy Installer | Full Package |
| Nucleus / ROCK: | See Help Center | |
| Android APKs: | Roon Remote | Roon ARC |
† Information on loading Roon on Linux can be found here. Please use the files linked here in place of those from the help center article when loading earlyaccess.
