Roon Rock 10i7 nvme rom. 16Gb ram
Router Vodafone. Amplifi Alien. Switch amplifi
Streamer ropieee. RME adi 2 dac. Khadas tone 2.
Large music
There is a problem with ARC, it may be a problem between the router and the amplifier.
Thanks for the help.
This is the message -
“external_ip”: {“actual_external_ip”:“95.39.xxx.xxx”,“router_external_ip”:“192.168.x.xx”},
“status”: “status”: MultipleNatFound
“upnp_autoconfig”: {“server_ip”:“192.168.xxx.x”,“found_upnp”:true}
I too have an Amplifi Alien and I’m getting the same error. I wonder if we have to set custom port forwarding rules.
Have you found a solution?
noris
Split this topic
3
St_One
(St. One)
4
Me too
Same error~…
"connectivity": {"status":"NetworkError","status_code":502,"error":"error: Error: connect ECONNREFUSED 118.XXX.XXX.118:55002, response code: undefined, body: undefined"},
"external_ip": {"actual_external_ip":"118.XXX.XXX.118","router_external_ip":"192.168.1.102"},
"status": "status": MultipleNatFound
"natpmp_autoconfig": {"status":"NotFound"},
"upnp_autoconfig": {"server_ip":"192.168.104.1","found_upnp":true}
Angel_Perez
(Angel Perez)
5
I solved the problem. The solution was in the router configuration.
system
(system)
Closed
7
