My Roon Core is docker based (using steefdebruijn/docker-roonserver:latest as docker image)
The docker host machine (Linux) is on Ethernet to router, and my Mac (on MacOS 12.6) is connected to the local net via Wi-Fi 6.
I use Dragonfly Cobalt (Roon tested USB DAC) as audio device.
I have 16447 tracks.
I use Dragonfly Cobalt (Roon tested) as audio device.
Before opening
Roon
MacOS
uses Cobalt as audio device.- I set the sound volume to about 10% on
MacOS
After opening
Roon
Roon
takes over Cobalt as audio device (exclusive mode)- I then try to adjust the sound volume in
Roon
Observations:
- Even I set the volume to 100 in
Roon
. Cobalt still outputs low volume to my headphone.
Recall : When Cobalt is in exclusive usage in
Roon
, I cannot control sound volume fromMacOS
native controller. However, it seems thatRoon
has exclusive but not full control of this audio device (Cobalt) at least no full control in terms of sound volume. -
Current solution:
- Pause the music (wait about 10 second so that Cobalt is released form Roon exclusive mode)
- Switch MacOS output to Cobalt
- Set volume to 100 in MacOS Sound controller
- Get back to Roon
- adjust volume in Roon
- start listenning.
My comment: My current solution is very inconvenient because after closing Roon I shall never forget to re-adjust the system volume (in MacOS Sound controller) from 100% back to an affordable sound level before any other use. However, my bad memory always surprises me.
Summary: After upgrading to Roon 2.0, Roon is unable to fully control the sound volume on Dragonfly Cobalt
Is this a normal behaviour? I don’t thing this issue has been existing before Roon 2.0 update.
