I just updated my Core with 2.0 and downloaded the ARC app to my phone. The ARC app on my phone works fine but my pre-existing regular Roon remote apps (on my phone, iMac, and two laptops) at my home can no longer connect to the Core.
You need to update the mobile apps to the latest versions available in the respective app stores.
Thanks. That worked perfectly. I looked initially and didn’t think so because it didn’t say “Update” in the App story as would be more common.
And thanks for the upgrade! If it all gets working (which it seems to be doing) it’s a fabulous improvement.
