Intel NUC 7i7 with Roon ROCK Version 1.0 (build 227) stable
Unifi 1 gb wired
Bluesound devices, a Ropieee etc
100 000+
I had a message in my inbox yesterday evening CET+1 time about 2.0 and ARC. I clicked on the link on my iPhone and downloaded from AppStore. The app said my core was not found.
I went to the Roon app on my phone, it said that there was updates. I clicked yes, and it updated the app on my phone, but it couldnt upgrade the Core.
I went to my windows 10 laptop and tried upgrade from there. It upgraded the remote, but the core said it was an error checking for an update.
I have now deinstalled ARC and Roon app on my iPhone and deinstalled Roon on my win10 laptop and tried installing the legacy 1.8 on m laptop. Error checking for an upgrade. What to do?
I reinstalled the Rock OS, it told me it was reinstalling and ugrading, and that it succeeded. It still tells me that I have Version 1.0 (build 227) stable installed
Does anyone know if there is a way to upgrade Roon Server Version 1.8 (build 923) stable on a ROCK OS to the latest (1126?) other then from a remote client? Mine seems to have got stuck on 923 although I have done “Upgrade All Devices” many times. Tried Putty but it wouldnt let me in.
Just to give an update on this crap. Since Roon apparently not is going to rollback this half baked update I tried to follow the instructions on https://help.roonlabs.com/portal/en/kb/articles/roon-1-8-2-0-migration-faq-16-9-2022#RoonOS_Core_18_Legacy_Nucleus__ROCK to see if my RoonOS/Roon Server would take an update with the method of adding the roon 1.8 legacy in a branches folder. It wouldnt. I still have OS Version 1.0 (build 227) stable and Version 1.8 (build 923) stable there after 3 reinstall tries and some reboots.
It says “Reinstalling latest software. This can take some time to download and install. Please wait until it is complete.” while in process and “Successfully reinstalled system.” after. Still on Version 1.8 (build 923) stable though. Pings fine and answers to Web GUI commands.
09/22 13:35:33 Error: [appupdater] While downloading update: System.Net.WebException: Name or service not known (download.roonlabs.com:80)
your machine cant download the build because it cant resolve this DNS… check your DNS settings and maybe just give the box a reboot and hopefully it’ll work next you hit reinstall?
