Thank you for the update. Based on the screenshot attached, you need to send the database located under the /Container/roon/RoonServer/, but it would be better if you would zip and attach the whole roon folder, including roon-backups and other subfolders.
I tried that. Took just as long. Now it’sfinally compressing, but the file is gigantic. I don’t know if I’ll be able to send it. It’s compressing a 7Gb file into 4Gb. Is it supposed to be that big??
Can i just say - you all are AWESOME… Thank you so much for spending the time and effort to help us on this! I expect to have an update on this for you all in the next day or so.
Not sure if it is related but this morning most of my Qobuz library disappeared. I started a separate post with support. This has happened before, some years ago.
