Hello, Since updating to Roon ARC 1.67 on my iPhone 11 Pro Max, Roon ARC needs 20 seconds to show the Recent Activity and currently playing song. Albums opened during this time are also not showing any songs and can‘t be started to be played. I‘ve already reinstalled the app, this unfortunately didn‘t fix the issue. Thank you for your help
I‘m using an Intel NUC running ROCK and connected via LAN-cable to a FritzBox router
Hi,
All albums are affected, streamed, locally stored and downloaded.
The slowdown occurs after a downtime or when opening it after manually ending the app. It doesn‘t occur while actively listening to music.
I‘ve also uploaded a video showing the opening of the app and navigatibg to an „empty“ downloaded album.
Best wishes and thank you for your help!
Thanks for getting back to us with that information. I’ve added it to the ticket we have open with our developers. We’ll keep you updated here as soon as we hear back from them.
At your convenience, please use the directions found here to locate the RoonServer folder housing your Roon database. Zip (compress) the entire RoonServer folder and upload that at the link provided at the top of this post. Thanks!
Hi @destaris,
Thanks for uploading your database for us. I’ve attached it to our ticket with the developers. Once they provide an update on their investigation, we’ll follow up with you here.
We wanted to reopen this thread as we’d left it unresolved before it auto-closed.
Development prepared some fixes in the last ARC release that should have helped improve performance and relieved some of the symptoms you reported here.
How have things been performing on your iPhone since we last checked in on this thread?
Thank you for getting back to me. As of today I’m using RoonARC 1.69(369) and there is unfortunately still a 20 second delay between freshly starting Roon ARC and being able to enter the player or songs in albums loading.
Just to maybe give more information, this happens both on WiFi and Mobile Data and impacts both streaming albums and albums which are locally stored on my ROCK and downloaded in ARC. During those 20 seconds, I can enter albums on my home page (Recent activity, Listen later etc.) but the albums will appear as having no songs, even downloaded ones and can’t be played. Search also doesn’t show any results in that timespan.
I sincerely apologize for the delay and truly appreciate your patience - progress on this issue has taken longer than we anticipated.
Our development team is still actively investigating and committed to finding a solution that improves things for you. While we don’t have any new updates or next steps at this time (and no additional info is needed from your end), we’ll temporarily close this thread for now.
As soon as we have an update, we’ll reach out right away. Thank you again for your understanding and for bearing with us.
