Hi, first of all, thank you for implementing the new Roon ARC functionality. I’m having trouble getting ARC to connect from outside my network. I have tried the different solutions suggested by the Roon team, but they have not worked. I include the error message that the system gives me to ask for help. I will appreciate a solution to be able to use ARC away from home. Thanks and kind regards.
“connectivity”: {“status”:“NetworkError”,“status_code”:502,“error”:“error: Error: connect ECONNREFUSED 188.76.73.28:56000, response code: undefined, body: undefined”},
“external_ip”: {“actual_external_ip”:“188.76.73.28”,“router_external_ip”:null},
“upnp_autoconfig”: {“server_ip”:“192.168.1.1”,“found_upnp”:true,“error”:“<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/\” s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/\“><s:Body><s:Fault>s:ClientUPnPError<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">501ActionFailed</s:Fault></s:Body></s:Envelope>”}
Moved to the support area
Please fill in the system information requested as well as your country, ISP and detailed networking information.
Country: Spain
ISP: Jazztel
Roon Core Machine: Mac Mini M1
Networking gear: Livebox + (Orange)
Conected audio device: Cambridge Audio 851N
Number of tracks: 55.180
Description of issue: ARC error connecting
Have you followed the Roon ARC configuration guide?
Have you first updated the Core to Roon 2.0? And also updated the Remotes?
Do you have a fixed or dynamic IP address for your internet connection?
In my case (Roon ROCK on Intel NUC) my ISP (BT Halo FTTC) does not give residential customers a fixed IP address, so I updated my Core and Remotes to 2.0, and it all worked just as 1.8 had done, no issues.
I then had to implement a Dynamic DNS (DDNS), there are several free solutions. I have an ASUS RT5300 Router (not the BT Smart Hub which is supplied as standard). Asus have their own DDNS facility, which is free and very good, but I could have used any dyndns service. Having set up the DDNS, I had to create a port forward rule, as described in the Roon documentation. I then installed Roon ARC on my iPad, and initially it did not work as it could not connect. A few minutes adjusting the port forward rule sorted the issue and it worked.
I then installed Roon ARC on my android phone, it connected and configured, and now it all works.
I hope this process helps you out.
Hi, There have been some changes to my error message on the ARC connection. Below I put a screenshot in case any member can guide me to a solution. I still can’t use ARC outside of my house. Thanks in advance.
You haven’t opened up access to your core from external.
Have a look at this post
Hi, I finally managed to solve the ARC connection problem. I have made a port forwarding configuration in my router and ARC has connected. Thanks for your help. Kind regards.
