Hi! What’s not quite right with Roon? · None of the above quite fits
None of the above quite fits · None of these quite match
Tell us what's going on · Roon ARC shows "unauthorized," and Poor Connection
Tell us about your home network · Xfinity XB7 modem/router; Roon and Arc are both on the wifi
I should add that ARC is running on the same WiFi network as the Roon Server (on a Mac mini M1), so I don’t get “poor connection.” You see with WiFi is strong at the top of the screen. Second, I don’t get “unauthorized,” either. Thanks for any help!
vadim
(Vadim)
January 20, 2026, 11:43am
3
Hello @Niels_Schaumann ,
Thanks for the clarification.
As a next step, could you please try fully reinstalling the Roon ARC app on your mobile device?
Specifically:
Uninstall Roon ARC
Reboot your phone
Reinstall Roon ARC from the App Store / Play Store
Launch ARC again and check if the “unauthorized” message and connection warnings persist
This can help clear out stale authentication or cached data that may cause inconsistent ARC behavior.
Please let us know how it goes, and we’ll continue from there if needed.
Hello Vadim,
OK, that did the trick. All seems to be working right now.
system
(system)
Closed
January 21, 2026, 9:14pm
5
